Need help changing Rear Bearings on my 1998 Xplorer 400.
Old 05-13-2005 | 05:06 PM
Xplor's Avatar
Default Need help changing Rear Bearings on my 1998 Xplorer 400.
I am changing all the bearings I can on my 1998 Xplorer 400. 3500 miles of muck seems to have seized up a couple already.
I am having a problem with the rear bearings in the axle carrier. Axle is out and sprocket/chain assembly is out of the way. How do I get the bearings out?
Plus, what other bearings would you guys recommend changing besides the ones for the front wheels and the rear axle?
Thanks!
Brian
Old 05-13-2005 | 06:04 PM
CED's Avatar
CED
Get a long punch and drive them out from the opposite side.That's about it for bearings.The swingarm has some bushings in them,just check the side to side play,if it doesnt rock,you should be ok.
Old 05-13-2005 | 07:09 PM
Xplor's Avatar
I have the good old 3 chain system.... what about where the two front chains intersect and also where the two front drive shafts meet? Any bearings there?
Thanks, still trying to get bearings, seals and spacers out of the axle assembly... not too easy.
Brian
Ean
12-19-2022 09:48 AM
clsharky
07-13-2015 03:07 PM
honda71
07-12-2015 06:56 AM
rcappie4
07-10-2015 05:54 PM
Jkfx400P
Sport Quads
07-05-2015 11:33 PM
