TrailBlazer's a goin' to hell! =(
Originally posted by: Doctorturbo
Put the air filter on it first and you might not have to rejet. You are already rich and a good filter will lean you out. Pop on the filter and go from there.
the air is thinner the higher up you go. so you would go rich at higher elevations. I would try a k&n filter and see if it get's better. If it's better but still too rich then hack up the airbox and let a little more air in there
