400L limiter rpm module?
Old Jun 24, 2005 | 03:04 PM
scramblered's Avatar
Default 400L limiter rpm module?
it is called a limiter rpm,hub,gnd,lr-83-1 at $90 each,
if you cannot understand where it is located,it is item # 30 at part land
.com electrical schema of 400 scrambler,i would like to known if any modded heads out there have disconnected that thing and what was the result then,it is the right module in front behind the plastic.thanks for any inputs.
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
