front wheels enguage when in 2wd...???
Old Jul 9, 2005 | 03:09 AM
DANO38's Avatar
Default front wheels enguage when in 2wd...???
So last weekend I noticed at the end of a 100 mile mostly dry trip, I couldn't slide the back end like I wanted to cause the front wheels were enguaging... but I was in 2wd??? I've heard of others having this problem, but never did on my '03 sp600, or on my new '05 until
now. Did anyone ever determine the exact cause???
Old Jul 9, 2005 | 07:27 AM
polarisbear500's Avatar
since no one else has chimed, i will do my best...although i haven't had this problem.. first, see if the AWD light is on when you slide the swithc to AWD...if it is not, then i am guessing your switch is bad and some how leaving the AWD on all the time....
second, if the switch is good, how is your speedo acting, i know they can effect the AWD system....
that is the only 2 i can think of rite now, but like i said, i don't know, these are just ideas until someone else comes along.-PB500
Old Jul 9, 2005 | 09:25 AM
jefffoxsr's Avatar
Mine does it too. I think the Plate or whatever it's called can become magnetically charged. At least that's what I've read. I've read hundreds of posts on it and I'm not much further as a result. Many of the quads do this though.
Old Jul 9, 2005 | 12:34 PM
ftwflh's Avatar
It is a common problem in the new differental where the hubs are in it.It should be covered by warrenty.
Old Jul 9, 2005 | 12:37 PM
XtremeSkier's Avatar
mine only does it in the snow, ive had it kick in when i've been spinning out alot. So i just leave it in 4 wheel drive and it doesnt do it in the snow anymore, never had it happen anywhere else for me tho
Old Jul 9, 2005 | 01:38 PM
Polaris500HO4x4's Avatar
check the Gear Case Lub level and then change it.. there is probablly water in it or it is low causing it to engage
Old Jul 9, 2005 | 05:31 PM
Zbart1's Avatar
Like someone said this is a common problem with that year. They changed to a single Hilliard clutch in the front and have had problems with them.
Not going to get into the dynamics here but if it’s under warranty take it back to the dealer and you are going to have to raise hell because they will tell you that there is nothing wrong, but there is and there is a Polaris bulletin on it.
If you’re not under warranty change the fluid in the front and it may fix your problem temporarily but the problem is in the design.
Old Jul 9, 2005 | 10:38 PM
tyler711's Avatar
That can happen whent the wheels get spinning fast enough. THe scrambler still has the outboard hubs, right?
Dano - check the fluid first. That's always the problem with the outboard hubs on my xplorers.
Old Jul 10, 2005 | 01:02 AM
DGScrambler400's Avatar
definatly change your hub fluid. drain them, and refill them until fluid runs out at the 3 or 9 o clock position
Old Jul 10, 2005 | 01:06 AM
tyler711's Avatar
He has the center mounted hub. But changing the fluid is still a good idea.
