Gear Removal from gearcase 400L
Old Jul 20, 2005 | 10:14 AM
jcrcr254's Avatar
Default Gear Removal from gearcase 400L
I am trying to take out the innards of a gearcase from a 95 400L 2x4. I have taken off the first bearing, needle bearing and gear and now I am stuck. I know this is a little vague, but how do I remove the shaft and gears that the dogs are on so that I can get out the big main gear? Any help would be appreciated.
Thanks
R254
Old Jul 20, 2005 | 10:25 AM
CED's Avatar
CED
You should be able to tap it out with a rubber hammer,if not you may have to heat the case a little.
Old Jul 21, 2005 | 03:47 PM
jcrcr254's Avatar
CED,
First, thanks for responding. Second, the problem that I am actually having is that the dogs are holding the shaft and gears in. How do I get it so that the dogs are not in the way to pull that shaft out? Man, I know this is hard to explain, but if I could move the shift dogs, I would be about to get the one shaft out that is holding everything else in.
Thanks
R254
Old Jul 21, 2005 | 03:56 PM
ATVnRocks's Avatar
Are u referring to the shift forks??? If so, the shafts they are on should pull out of the case, then remove the forks, hope this helps.
ghost civic
Jan 15, 2020 07:43 AM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
