driven clutch 98 scrambler 400
Old Jul 27, 2005 | 10:45 PM
ftwflh's Avatar
Default driven clutch 98 scrambler 400
The spring on the new one is for a newer Scrambler and will work but will backshift a little faster.Set it at 2-2 or you can use the old red spring and set it at 2-2.
Old Jul 27, 2005 | 11:13 PM
GST97's Avatar
This secondary came from a 99 Sport 400, which seems to have the same parts in that area as the scrambler...
So... by faster backshift, do you mean it will decellerate faster when you let off the gas?
I guess also, I could just try the white spring and try the red spring... it's quick to change out, heh. That would let me know which one I like best [img]i/expressions/face-icon-small-wink.gif[/img]
-Chris
Old Jul 27, 2005 | 11:23 PM
GST97's Avatar
At second glance, maybe I won't be using this white spring.
I know the red spring is straight as could be, but this springs' ends are way off center...
Picture of spring
Old Jul 28, 2005 | 12:17 AM
GST97's Avatar
OK, after more investigation, I found out this secondary came from a 99 sport with a HSP clutch kit.
After visiting their website I found a picture of the white spring and it is not supposed to be straight.
I guess I will try both [img]i/expressions/face-icon-small-smile.gif[/img]
-Chris
Old Jul 28, 2005 | 07:17 PM
  #15
ftwflh's Avatar
Hey just play with it and try both and see what the differance really is.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
WilliamBos
Sep 6, 2015 10:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
