What to do with 99 trail boss?
What all can i do for performance and looks for a 250 trail boss? Im not having much luck searching on the net. Will trailblazer parts fit since they have the same motor? Also is there any suspension modifications that can be done to make it more like the trailblazer? Thanks...
We do offer a few parts that will fit right on the trail boss 250 ie: filter, clutching, porting, carb kit, and misc. bolt on goodies. The part you ar probably looking for the most would be a pipe I'm guessing, we have had a couple of customers in the past purchase the pipe and change the mounting so that it would work on there machine if you are interested. But you should know there are parts available for your machine. If you wish to look at them check usout @ www.hotseatperformance.com keep in mind that most of the 250 trail blazer parts will go right on your quad except the pipe.
you can get allot of extra gooodies for that. It also sll depends on what ur trying to do. Performance, add a k&n air filter, change the mufffler, maybe even a jet kit, om sure they have other things to.
oliveiracarlos
19
Nov 11, 2015 05:49 AM
craacker
Sep 9, 2015 04:32 AM
Elkaholic
Sep 6, 2015 02:44 PM
