Polaris Predator (for on road)
Old Sep 25, 2005 | 10:41 PM
Polaris500HO4x4's Avatar
Default Polaris Predator (for on road)
Originally posted by: tyler711
Originally posted by: hayride
The only problem i have is that the rear drive train has no slip so when I go around a corner both tires are pulling at the same speed.
Jef
Does this loosen up the rear end a lot on corners? Or is it not so noticable? That solid rear end is going to burn through tires...
i have over 2500 miles of road riding and im just ready to change tires, the fronts are bald but the back have a good 1000 miles left on them
Old Sep 25, 2005 | 11:57 PM
tyler711's Avatar
Jef
Maybe quads just don't have the weight to kill the treads that fast? When you turn on an atv, there is usually enough lean to lift a good bit of the weight off of the inside rear tire.
2500 miles on one set of tires? I changed out the 489's on my sportsman after 1000 miles. They still had some tread left, but only about 1/2 to 5/8 inch. Not enough to keep me moving.
Nondem
Feb 22, 2020 12:20 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
