Sportsman 500 spark problem (electric only)
Old Jul 28, 2005 | 12:22 AM
WildThingQc's Avatar
Default Sportsman 500 spark problem (electric only)
I'm working on my friend's Sportsman 500 (don't remember which year).
The starter does turn but there is no spark. With the pull starter, if the engine turns at similar speed as the electric starter, there is no spark too. But if I pull it HARD, there is some spark.
We can start the engine with a hard pull but we can not start it with electric starter !!!
Does someone have any idea ? durty flywheel ? magneto problem ?
Thanks, Pierre
Old Jul 28, 2005 | 11:56 AM
ATVnRocks's Avatar
Something has knocked the pick-up coil enough to open the gap between the pick-up & flywheel, that's where I'd start.
Old Jul 28, 2005 | 02:43 PM
Thanks, I will look at this asap. I will remove the flywheel maybe tomorrow.
If someone have another idea, don't hesitate...
Thanks again,
Pierre
Old Jul 28, 2005 | 03:39 PM
ATVnRocks's Avatar
Thanks again,
Pierre
Why??? Don't u believe me??? Just messin with u, all u have to do to find this out is to remove the recoil housing, the pick-up is on the outside of the flywheel.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 28, 2005 | 04:49 PM
Sorry, my english is not very good. I do believe you !!
Did you see it in the past ?
You said : "that's where I'd start.", that's why I asked if someone else had another idea.
I will try to remove the recoil but I don't have time now.
Thanks, Pierre
Old Jul 30, 2005 | 05:38 PM
I removed the recoil housing today and you were right, the pick up coil was bent.
I was trying to figure out how could this happen (into a closed housing) but I saw the starter have been changed. Maybe a loose part did it...
Excuse me again and thanks for your help !!
Pierre
Old Jul 31, 2005 | 03:02 PM
ATVnRocks's Avatar
Glad to have helped.[img]i/expressions/face-icon-small-smile.gif[/img]
njrider64
Jul 4, 2017 01:40 AM
jrooker6
Jun 17, 2015 12:28 PM
jag6510
Jun 15, 2015 05:59 PM
sae156
1) Engine problems..
Jun 3, 2015 01:45 PM
