Clutch help BUBBA
Old Aug 12, 2005 | 01:42 AM
  #21
baxy's Avatar
Default Clutch help BUBBA
sorry I just went back to thr royal distributing website and it is much less around $400 canadian depending on which silencer
http://www.royaldistributing.com/ser...49&submit.y=13
page 93
Old Aug 12, 2005 | 01:55 AM
  #22
baxy's Avatar
without the pipe I don't think I could run the factory cyclone calibrations
I think I'm on the right track by adding weight
going to try 2-2 on the secondary also
Old Aug 12, 2005 | 02:10 AM
  #23
fishslab's Avatar
That's it. I realize now I was thinking about the Cyclone pipe they make, but don't list. Sorry I got them mixed up. I do recomend getting a pipe for it. Your clutching is gonna be hard, because your running a hot top end with a low output pipe.
Old Aug 12, 2005 | 02:24 AM
  #24
baxy's Avatar
ya I know
I should know better from all the years of modifying my snowmobiles but I'm kind of trying to get the parts I have working as good as possible so I can sell it and start a winter project
I'm hoping to find a 400 scrambler 4x4 that needs work build it into something hairy!!!!
Old Aug 13, 2005 | 01:58 AM
  #25
baxy's Avatar
ok these clutches are crazy to work on
I started with "16" weights stock and the belt side clearance was perfect
went to "F" weights and had to remove a ton of shims from the spider just to get to the max side clearance
NOW I have put in "10MB" weights and I have at least .080 side clearance
anyone??
Old Aug 13, 2005 | 02:39 AM
  #26
baxy's Avatar
are the rollers supposed to touch the weights when the clutch is at rest (engine off) or should their be a little free play between the weight and roller???
or is the movable shive supposed to bottom against the spider???
Old Aug 13, 2005 | 09:32 AM
  #27
Bubba297's Avatar
On the atv clutches, if you use the 10 series style weights (race weights), then you have to discard the small thick clutch washer on the clutch bolt and use a snowmobile larger thinner washer. That pushes the outer sheave in just a little to make up the clearance difference. I have ran it the other way before and usually all I have found is that it causes a higher rougher engagement and will also affect shiftout slightly.
Old Aug 13, 2005 | 11:49 AM
  #28
baxy's Avatar
I will have to discard that steped spacer that is in the end of the clutch for that to work
I don't reallr see a purpose for it as it only fits tight into the end of the clutch shaft and not on the bolt
Old Aug 13, 2005 | 01:30 PM
  #29
baxy's Avatar
ok
10MB
white primary
violet secondary
36/40 HDP helix
2-3 tension
.020 belt side clearance
still a little early to road test up the alley but I will in about a 1/2 hour or so!!!
Old Aug 13, 2005 | 02:43 PM
  #30
baxy's Avatar
it works good shifts out all the way
seems a little lazy out of the hole and I think in high range in the mud it would probably slip the belt
I think I might order some "G" weights and try them
maybe try a different spring
