2004.5 rattle noise in the front end
Old Aug 11, 2005 | 11:28 AM
NHarrison2's Avatar
Default 2004.5 rattle noise in the front end
When setting in Nuetral rebbing the engine, it does not do it. Only when going down the road. I think its either front wheel bearings or slop in the front axle assembly.
Noble
Old Aug 11, 2005 | 04:27 PM
Mudlover600Tw's Avatar
It started with a little noise only when appliying brakes or in 4 wheel drive.
I will try to get a pic on to show you the repairs.It wallowed out where the A-Arm ataches to the frame it is was the lower one on the right hand side.
Old Aug 11, 2005 | 04:30 PM
Again check your tire grab it and pull forward to back check for sloppy or any movement at all.
Old Aug 11, 2005 | 04:39 PM
Originally posted by: NHarrison2
Could you explain a little more on the tabs. Not sure what you are talking about. Did this over time wallow out or was it like that from the factory? Did you weld them or the polaris shop? Do you have a pic of this by any chance?Noble
Noble look in my profile at the pipe pic.The red a-arm attaches to the frame by those brakets.It was slotted out worn and the bolt would move back and forth so the sound would be not always constant but always heard on hard top sufaces when on and off throttle agressively. Just check them by grabbing your tire and pull hard forward and back with your bike in park. If its fked the thing will move and you will hear the noise.Just a thought
PM if you need anyting else dude
Old Aug 11, 2005 | 04:57 PM
  #15
NHarrison2's Avatar
Thanks for all the help.
Noble
Old Aug 16, 2005 | 02:47 AM
  #16
Dogboy's Avatar
I've got a 05 700efi and it makes the same noise.
Two other guys that I ride with also have the same problem.
The one has a 04.5 the other has an 05 like mine.
From what I'm told this sound is normal and nothing to worry about.
We will see I've got around 300 miles on mine so far.
Old Aug 16, 2005 | 06:02 PM
  #17
NHarrison2's Avatar
I have 2100 miles on mine but the noise is getting louder all the time. It bothers me to drive it.
Noble
Old Aug 17, 2005 | 11:49 AM
  #18
Noble , Did you check what i told u about?
ronnierhino06
Nov 9, 2015 12:56 PM
Mikesohio
Jul 26, 2015 10:51 AM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
D-Hagz
Jul 4, 2015 02:19 AM
