HPD high output ignition. CED?
Old Aug 12, 2005 | 01:29 PM
scramblered's Avatar
Default HPD high output ignition. CED?
oh yeah,the race pipe is a real craftsmanship,i got the new hand built
unit as well as darell told you,i run the 2 degrees retard timing as they
stated and had any problems with it yet and is pretty easy to tune,
stock timing will produce more low end torque but engine run hotter
and has less top end,my 2 cents is to go for the pipe first...
ps:it sound like a too lean pilot jet or needle the bog you're talking about.
Old Aug 12, 2005 | 08:43 PM
Kahnman's Avatar
Seems I am getting differing opinions here. Pipe or Ignition? I'm so confused.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 12, 2005 | 10:43 PM
CED's Avatar
CED
Try the 35 pilot first,then check your timing,i always ended up at stock timing.Then go from there.
Old Aug 13, 2005 | 12:59 PM
Kahnman's Avatar
When I first opened the flywheel, the timing was set at full retarded. I bumped it up a little but not in the middle top dead center as my Trail mod was. I found a 35 pilot and iridium plugs at a dealer nearby. I will try them both. Should I set the timing to top dead center? By the way, CED, would you mind if I talked to you? I can call you if its ok. Kahnman1481@yahoo.com. Thanks.[img]i/expressions/face-icon-small-blush.gif[/img]
Old Aug 13, 2005 | 05:08 PM
  #15
CED's Avatar
CED
You've got mail.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Sw00p
Sep 24, 2015 02:50 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
