The Polaris Nuthouse
Old Feb 25, 2008 | 11:40 PM
  #4961
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Default The Polaris Nuthouse
<div class="FTQUOTE"><begin quote>Originally posted by: Sparky8370
Yeah I think that would be a little much for one of these. GM doesn't want you to shave them period. I'm just rolling the dices on this one, although I think I will be fine. I'm taking my time putting it back together to make sure everything goes right. I'm also trying to save most of the gaskets that were there already. The cylinder head gasket set from GM costs $534 and doesn't come with the head gaskets, they are just over $100 each and you have to buy them separately because there are many different ones available. I just bought the head gaskets and will buy the others as I need them. I guess I could have just bought the gasket set and still saved $6,000.00 over having a dealer do it.</end quote></div>
Dammmm....Im sticking with a gas engine for a while longer.
Old Feb 26, 2008 | 09:58 AM
  #4962
Budman650's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: drlang
Mid life stupidity? OOPS I mean crisis. What in the world do you need-want that for?</end quote></div>
I'm nuts and have been known to be suicidal
Old Feb 26, 2008 | 10:28 AM
  #4963
Budman650's Avatar
Wait, did you mean the cycle or the pony keg?[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 26, 2008 | 11:53 AM
  #4964
drlang's Avatar
Fast only has 1 S. Sick kids, home from work. Yippee, hope I don't get it. Nasty flu bug. The DR. says it looks like a strain from the Lake Havasu area.
Old Feb 26, 2008 | 02:43 PM
  #4965
Budman650's Avatar
strain from Lake Havasu? The only strain we have here is on my eyes watching the girls at the beach today.
What were you saying about the weather in Wis?
Old Feb 26, 2008 | 03:39 PM
  #4966
drlang's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Budman650
What were you saying about the weather in Wis?</end quote></div>
Why you gotta be like that?
Old Feb 26, 2008 | 04:20 PM
  #4967
PapaGrande's Avatar
<div class="FTQUOTE"><begin quote>What were you saying about the weather in Wis? /Budman</end quote></div>
Haa,you are back in business, again!
Whats up there in Wisconsin weather?
We have got only water here in Scandinavia all the winter.
Waiting summer and BBQ.
Old Feb 26, 2008 | 04:48 PM
  #4968
drlang's Avatar
Hey PG, nice to see you. Southeastern Wisconsin has had a dandy winter. Record snow fall, record cold, things are different everyday around here. Spring is coming soon though.
Old Feb 26, 2008 | 10:04 PM
  #4969
Sparky8370's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: mywifesquad
Dammmm....Im sticking with a gas engine for a while longer.</end quote></div>
I'm actually thinking about getting a Yukon Denali when they come out with the new 4.5 duramax (And once I can afford it!!!!!!!)
Statistically, I shouldn't have had this problem and it should have lasted a lot longer than a gas motor before needing this kind of work.
I have an even bigger problem now. I speed read the directions. Where it said to follow the manufacturers torque pattern I read it as do it like the manufacturer does. I was putting in ARP head studs though. I torqued to 50Nm in sequence, then 80, then 60*, then 60* again just like GM says. But I was noticing that the torque just seemed too much. I went back and re-read everything and I was supposed to torque to 125 ft/lbs and use the manufacturers torque pattern only. I torqued almost all of them over their yield strength of 165 ft/lbs (The highest one read 291.2Nm when I was done the final 60* which is equal to about 215 ft/lbs)
So now I should be buying a new set of studs and gaskets which will cost me another $800, plus I'll have to tear down all the work I've done. I think I'm just gong to cross my fingers and finish assembling it. I've already redone most of the torqeing, I just hope I didn't screw anything up.
Old Feb 26, 2008 | 11:16 PM
  #4970
KTM Patrol
Former Chinese POW!
So now I should be buying a new set of studs and gaskets which will cost me another $800, plus I'll have to tear down all the work I've done. I think I'm just gong to cross my fingers and finish assembling it. I've already redone most of the torqeing, I just hope I didn't screw anything up.</end quote></div>
I might wait for the bugs to be worked out of that one. [img]i/expressions/face-icon-small-wink.gif[/img]
How many miles did you have on the Duramax Sparky? [img]i/expressions/face-icon-small-confused.gif[/img]
I hate it when I do that.[img]i/expressions/face-icon-small-frown.gif[/img]
Thats probably what I would do also. (crossedfingerssmiley)
