hard to shift - melted plastic?
Old Aug 20, 2005 | 11:23 AM
redneck42woman's Avatar
Default hard to shift - melted plastic?
I have a Polaris 500 HO. Has anyone experienced issues with shifting? My bike seems hard to shift compared to other bikes (the same model) I have ridden. The dealer said it happens with all the Polaris's but I thought I would come to the "pro's" and ask. It's a 2005, just bought it a couple of weeks ago. I also read a few comments about plastic melting, I haven't seen this on the side of my bike but under the seat there is a small hole and it looks like something melted.....anybody have any ideas? The dealer has said he does not know what this is......woohoo for warranty but still would like feedback from you guys about possible problems.
Old Aug 20, 2005 | 11:26 AM
spyder6's Avatar
its going to be rough till it gets broke in, or if its REALLY cold, so dont worry about it and give it some time to loosen up. also, the melting plastics are only on the 800 EFI's so you dont have to worry about that either. good luck with your new quad
Old Aug 20, 2005 | 12:44 PM
crasher22's Avatar
On my 500HO (05) the removable side panel "male" tab that secures the panel has had it's head melted off.
I am sure a bit more heat tape would have helped,
Old Aug 20, 2005 | 10:09 PM
powerslider's Avatar
The shifting can be fixed, my 800 was very stiff also. Check the idle speed to make sure it's not to high, check the belt alignment, mine was off. You can also add a secondary clutch shim under the primary clutch spring to increase the preload just a tad.
Njrider1230
Jul 29, 2023 05:16 AM
nachop
Feb 14, 2018 06:57 PM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
mdrkcckv
Jul 22, 2015 09:10 AM
