How many cc's larger can i make my 250?
Old Aug 24, 2005 | 12:23 AM
DanMan83's Avatar
Default How many cc's larger can i make my 250?
Whats the biggest I can go with a 250, and how many cc's would it be in the end.
Old Aug 24, 2005 | 01:13 AM
Bretman's Avatar
Well I am not sure on how many cc's you will gain but i can tell you some up grades that will definantly help you out. You might want to try and get a white brothers e series slip on, that will make a huge difference. You might want to switch your filters to K&N, that will help preformance a little. Also maybe a jet kit or re jet your quad. Also a new air box, maybe aaaaaaaaa i think its called a hpd air box. Those will really add the ***** to your quad. This will make a big performance up grade. Also a clutch kit.
Old Aug 24, 2005 | 05:56 PM
DanMan83's Avatar
yeah i got an hpd pipe waiting to be installed, i bought it off of ebay so i have to order the manifold springs jets etc.... i was just curious on how far it can be bored and how many cc's i can get out of it
Old Aug 24, 2005 | 06:46 PM
scootergptx's Avatar
Supersock
Hired Gun!
Best advice is to talk to Rick Ritter and see what advice he gives you.
Old Aug 24, 2005 | 06:50 PM
Supersock
Hired Gun!
Hope the pipe you bought wasn't a DG, you'll be disappointed in it.
Old Aug 24, 2005 | 07:06 PM
stumpjumper400's Avatar
just boring it out isn't going to give you much if anything noticable. you are only wasting the amount of times your topend can be rebuilt. if you want more power, start with a pipe, clutch kit, and a better airfilter. or you could just call rick ritter as stated above.
an e-series slip on is a four stroke pipe, hence it won't work on a 2-stroke.
steve
Old Aug 24, 2005 | 07:17 PM
x_scrambler3's Avatar
If you are looking to make it have more cc you need to talk to AZ Bad Boyzzz they have a 7mm stroker kit that bring it up close to 300cc an the they have a 12mm stroker kit that uses the 300cc cylender an make it close to a 350 I think. But i know they have some fast 250 motor with there reedcage conversion
Old Aug 24, 2005 | 07:25 PM
Jayblazer's Avatar
do not bore it stroke it!!AZ badboys does some wicked things with the 250. that stroker will smoke a 400 from what im told...
Old Aug 25, 2005 | 01:11 AM
DanMan83's Avatar
oh ok tanks guys.........also that pipe i bought is an hpd i tlaked to hpd and we talked about the pipe and they said it was theres.......no the seller contacted me later and was like 'yeah i think i screwed up its an hpd pipe" so i thought to my self ah ha i got it for a good price too.
Old Aug 26, 2005 | 02:14 AM
tblazer's Avatar
Well you can see what i've done to my tblazer 250 below and i can tell you that it is a rocket for a 250. The only thing holding it back is good clutching but should have my spring and weights next week. I know a guy who is a dyno tester for Polaris and i was talking to him about putting a wiseco piston in mine and he said don't bother and just replace the rings. He said they weren't impressed with them, performance and durability wise, you either have great luck or terrible luck.
