Cold, cold weather starting.
Old Sep 18, 2005 | 11:22 PM
lusty's Avatar
Default Cold, cold weather starting.
I saw on another site that some Honda's have a primer for cold weather starting. Does Polaris have a primer for this purpose? Also, how do you fellas start your Polaris in say, -25C weather? BL
Old Sep 19, 2005 | 06:12 PM
tmorris1's Avatar
Choke it and hit the starter. Mine starts right up.
Old Sep 19, 2005 | 06:19 PM
tyler711's Avatar
My 400 started in -35*F with the choke and electric start. That's -37*C for the canadians.
Old Sep 19, 2005 | 06:32 PM
stormyseas's Avatar
-10 in the Michigan U.P. and my 400 started ok with a choke and a turn of the key.
Old Sep 19, 2005 | 06:37 PM
Bretman's Avatar
polaris has choke which is just as good as a primer. They will start in any degree of weather with choke.
Old Sep 19, 2005 | 06:45 PM
XtremeSkier's Avatar
i dont even use my choke, i just give it gas once it starts to turn over..i dont knwo if it's bad for it but i've been doing it since i got my quad and it still runs fine so yeah
Old Sep 19, 2005 | 07:13 PM
tyler711's Avatar
Just be careful in the extreme cold, the battery won't hold out long cranking a cold engine. But that's why the non-twins have a pull start.
Old Sep 19, 2005 | 07:19 PM
CaptainToyota's Avatar
I used to own a '97 Scrambler 500 4x4 and even in temps as cold as -20* F it fired right up. Just make sure you let the engine warm up a bit before you ride it hard.
Polaris' 0w-40 oil aids in cold weather starting.
Cap'n
ultangler
Nov 30, 2024 01:35 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
