1998 425 mag steering problem help
Old Oct 9, 2005 | 02:02 AM
icu812's Avatar
Default 1998 425 mag steering problem help
sometimes it wants to pull hard to the left. tomake it steer good again I will back up and turn sharpley to right and left then its ok for a while . are one of my front hubs not disengaging? where should i start to look? Thanks ......scott
Old Oct 9, 2005 | 09:33 AM
ftwflh's Avatar
Start with changong the hub fluid.
Old Oct 9, 2005 | 11:22 AM
tprice's Avatar
I am having the same type of problem with my 97 425 mag. It seems my right front wheel is not engaging, I have check the wires to make sure nothing is broken since I have had that happen before, but it also seems the 4x4 is not diengaging.
I was wondering if it could be in the electronic 4x4 switch???
Old Oct 9, 2005 | 08:09 PM
ftwflh's Avatar
Both of you need to take the hubs apart and clean them and put in new fluid.
Old Oct 9, 2005 | 09:46 PM
tprice's Avatar
How do I clean the Hubs??. I had some work done on mine(front axel replaced) and I know he charged me for oil for the hub. Howeve he may have just done it in one side but I am not sure
Old Oct 9, 2005 | 10:55 PM
ftwflh's Avatar
To clean them you will need to take them apart and reasymble them.You may need a manual to get it right.
mdrkcckv
Jul 22, 2015 09:10 AM
honda71
Jul 12, 2015 05:56 AM
1966F100
Jul 12, 2015 03:01 AM
Scottma518
Jul 10, 2015 12:42 AM
honda71
Jul 8, 2015 02:13 AM
