primary clutches
Old Oct 10, 2005 | 01:49 PM
baxy's Avatar
Default primary clutches
all this talk about upgading to an 800 [rimary for the lower starting ratio
sounds like a good plan to me!!!!
I have seen guys ask about weather or not they will fit a 500
I would say yes as polaris doesn't seem to ever change the taper on their cranks
but to be sure if you want a low ratio clutch for your 500 or smaller machine ....... use a RANGER clutch
they start out a lower ratio as well
Old Oct 10, 2005 | 02:24 PM
SPORTSMAN70003's Avatar
If you look at the 06's the 800 700 & 500 have the same primary clutches.
Old Oct 10, 2005 | 02:26 PM
baxy's Avatar
COOL
do these new clutches shift out and have the same top end that the old standard ones do??
Old Oct 10, 2005 | 02:30 PM
I'm pretty sure they do.
Old Oct 10, 2005 | 08:13 PM
nfox's Avatar
I am very impressed with the 800 primary on my 700 efi it will spin my 26" outlaw mst no problem anytime i want to, make sure to check the belt to sheave clearance before installing the 800 clutch mine was way off.
Old Oct 10, 2005 | 09:30 PM
Did your dealer remove shims or add shims behind the spider?
Old Oct 11, 2005 | 10:36 AM
Speedwerx's Avatar
Don't forget to change your belt in some cases as well.
Old Oct 11, 2005 | 06:00 PM
nfox's Avatar
They removed shims from behind the spyder.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
