any danger running weights that rattle?
I'm over shooting my power band on my quad with the mods in my signature and the polaris brown spring s55 weights.
I have a set of 10-56 weights I bought off ebay that rattle I was thinking of trying, will I mess anything up to do this? Can I just buy some new bushings? Also I need to know were to get the washer I need for 10-56's.
Should I just try some s58 weights to bring it down some?
First do you have a tach and what is the rpm of full shift out?This is the ONLY way to tell for sure what springs and weights you need.But if you want to try the 10-56s just swap the bushings with some good ones.But the S58s will probbly do better.
Thanks brad
I have the auto zone tac but havn't been able to get a signal. My lighting stator or regulator went out and I can;t power it. I hooked it directly to the battery but didn;t get a signal. based on my notes before it went out I'm getting about 6500-6600. I need 6300 or abit lower the 6500-6600 would have worked with the PWK but im in need of a new one to make that work. I'll try a bushing swap and see what I get I'm hoping I can find a twelve volt dril battery to power it.
Frisky2050
Apr 9, 2020 11:19 AM
trx430ex
Oct 19, 2000 03:30 PM
ScoobyDFW
Jul 23, 2000 05:50 PM
