secretive, Predator front brake fix??????
No one knows...........I think they were just designed/built wrong from the factor, and have been neglected ever since.........Mine only turn about 1/2 a turn on a pretty hard turn.......
i have an 06 pred, i have pretty bad brake drag. i roll the wheels very hard and they continue you roll for about 6 inches and stop. i dont really notice the problem much, but im sure it cuts atleast a few seconds off my drag time
All the fastest predators(nicholas/Rath/even hpd) have a brake mod done.Rath uses honda braks spindle and hubs,Not sure what nicholas uses but in the pictures I've seen the master cylinder is not stock.At one time I heared Hpd was making a fix,they said it was the master cylinder(brake handle).
SPYDER6--You say the 06 has it ,then i believe what i was told is BUll,I don't think the outlaws brake are different. I do believe polaris may try to fix this tho.
i mean, i can sit on the ground and roll my pred with my index finger no problem, but i can hear the front calipers grinding the disk without me even near the brake handle. the rear brake however does not have any brake drag
#15
It is just the front brakes i think.......haven't ever really tested my rear(because of the chain drag too)........There is just too much pressure in the brake system......some have fixed with little springs, but that sounds like a horrible idea to me.......
Many are fixing them with 300/400ex brake systems, and I think the 400sport/scrambler system will work too.
Doug, just cuts his off.......on the drag bikes......he doesn't use the front brakes........
