Snow Plow
Old Oct 19, 2005 | 09:42 PM
Dogboy's Avatar
Default Snow Plow
It's getting close to that time of year again, and I need sugestions
regarding using something other than the cable on my winch to lift the plow.
After a few uses the cable frays apart. Anybody got any thoughts? Do they make a synthetic rope small enough to work??
Thanks
Old Oct 19, 2005 | 10:01 PM
Bradracer18's Avatar
Default Snow Plow
I don't know how big of a boy you are......but I live on a farm, and we do our whole drive way, and in front of the shop(lots or area basically)........and ours is lifted by hand.......its not that hard to lift it by hand I think.........
I'm only 150lbs, so I'm sure you could do it too, but maybe you don't want to........
Anyways, we have a cycle country blade......it is great, works good, and has replaceable parts. It mounts pretty easy too(has a quick mount, that will allow dismount in about a minute).......It will work on other quads other than Polaris too, so that is a good option to have too.
Check my pics page, I think I have one of it on our sportsman........we added some round baler belt to the top so snow wouldn't go over the top.........
Old Oct 19, 2005 | 11:26 PM
new2atv's Avatar
Default Snow Plow
I replaced the cable on my winch with an Amsteel Blue winch rope. It's as strong or stronger then a cable and a lot harder to fray. If it does fray, it won't poke you like a cable. Another good thing is if you do happen to break it, you won't get the recoil like you would a cable. I've used it to pull myself out of some trouble spots and I've also pulled others out with it and it worked fine. I wouldn't hestitate to buy it again if I ever have too. I have a couple of pics of it in my gallery.
Old Oct 20, 2005 | 04:02 PM
mtpockets's Avatar
Default Snow Plow
Dogboy,
i've found that the cable won't fray if when you lift the plow you don't bottom it out. lift it just enough off the ground. i found that if you crank it as far up as it will go, then YES, the cable will fray.
(i've been plowing with an ATV for 7 years.)
no second cable needed. give it a try!
Warn2000 cables i've found fray. the Warn2.5ci and 3.0ci don't using my method.
~MT
shimanok2
Jan 29, 2016 07:37 PM
Irishman301
Sep 23, 2015 01:47 PM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
