Phoenix clarification
Old Oct 25, 2005 | 10:09 PM
nfritzsche's Avatar
Default Phoenix clarification
What exactly is the CDI, and is there any way to adjust it? Will the CDI from the 2006 work with the 2005, and would it make any difference in performance?
Old Nov 17, 2005 | 11:31 PM
BigBlueScrammy's Avatar
CDI stands for Capacitor Discharge Ignition. The CDI from a Phoenix is not adjustable. The CDI from an 06 will not work on an 05. I had heard that they changed the RPM range on 06, but can no longer verify that information. Polaris started using their own throttle housing on the new models. The wiring changed just a bit so now the 06 won't be an exact swap. The do swap, but you would have to leave the reverse limiter unhooked. Polaris did change the final drive ratio in the transmission in the 06 to make it higher geared to keep it from hitting the rev limiter so quickly.
Old Nov 18, 2005 | 12:55 AM
RickRitter's Avatar
Blue Scrammy ,
How did you figure all this out ? Looks to be correct from what I know .
Rick
Old Nov 18, 2005 | 03:02 AM
Because me and you talked on the phone.
Old Nov 18, 2005 | 12:02 PM
RickRitter's Avatar
Ahhhhhh ok ... I didn't recognize the nickname .
I finally had your name and nick in my head and straightened out and now a new nick ... :-)
Rick
Old Nov 18, 2005 | 02:52 PM
Don't forget to check your email Ricker.
bowhunter38
Jun 14, 2015 04:38 PM
Jun 10, 2015 11:20 PM
biggerisbetter
Jan 10, 2003 12:11 PM
Nordikwolf
Jun 24, 2002 02:18 PM
