EPI PINK SPRING INSTALL ???????
EASY...... Remove clutch plastic houseing; remove six clutch cover bolts on primary clutch and the center bolt (you don't need to remove the clutch from the quad) the spring is behind this cover slide it off the shaft slide the pink one on line up the x onn the cover with the x on the other part reinstall six cover bolts tighten each one about two truns at a time so the cover pulls up evenly. then tighten to 7-8 foot pounds, tighten center bolt to 40 foot pounds. put the plastic houseing back on and go for a test ride.
Jeff
Jeff
jrooker6
Apr 23, 2016 07:36 PM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
