home made front lift
Old Nov 30, 2005 | 05:22 PM
doctorvic's Avatar
Default home made front lift
I'm trying to make a front lift for my sportsman 400. I have made the spring spacer it's 2" tall but I did some reseach and I think i'm going to cut them down to 1.5". Here's were I need help the strut spacer would I make it the same height as the spring spacer or is it taller or shorter.
Thanks, Victor
Old Nov 30, 2005 | 05:50 PM
kj330's Avatar
What do you mean? spring spacer/ strut spacer.
I fabbed 2 inch spacer on my ATP 330 and my SP 700. all I used was a female (threaded on the inside, and fully galvanized) union, to two inch heavy duty electrical conduit. 2.00$ each at Lowes. put the factory washer on the top of the spacer. I will have picture up in a week or so..
Old Nov 30, 2005 | 05:57 PM
doctorvic's Avatar
What I mean is I have spacer that goes under the spring but to maintain the correct angle there is a spacer that fits under the strurt that is how all the real lift kits are. the hilifter kit has a spring spacer and strut spacer.
Old Nov 30, 2005 | 06:29 PM
doctorvic's Avatar
The reason I need strut spacer dimension is because I am making it out of 304 stainless steel the spring spacer is 6061-T6 aluminum I figured ss for the strut would be better because it will with stand almost anything. Please help me I need this before work tomorrow.
Victor
Old Dec 1, 2005 | 04:09 PM
kj330's Avatar
All I did was install a 2" spacer under the front coil spring. I simply moved the lower tube of the shock up 2" in the lower housing (the peice that clamps the lower shock??). The reason is so that it maintains the factory ride, but doesn' sag with my plow and bumper.
Old Dec 1, 2005 | 04:52 PM
doctorvic's Avatar
Thanks kj330 that was what I needed to know, i'm going to cut the strut spacer to 1.5" ( the piece that will fit under the lower shock) and i'm going to leave the coil spacer at 2" all I wanted was for the front to be a little stiffer than stock and around an 1.5-2" taller because of the winch, bumper and all the crap I hall on the rack.
Thanks again, Victor
Old Dec 2, 2005 | 10:12 AM
kj330's Avatar
me too it has worked well
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
