Does anyone have a scrambler with a rear brake that works?
Both of my Trailblazers work fine. I suggest that when you bleed the rear brake, use a clear hose to the brake fluid can or use a vacuum pump to assure that all the air bubbles are out. I noticed that the air bubbles are so fine, you can hardly see them.
I hope this helps you
Bryce
Bryce
my cyinder blew on my rear break. new one was around $80. so instead, i found on on Ebay for $4.00. They lock up like nothin-else. If you look for a new cylinder on EBAY, all of the sport/ scrambler ones should fit. (shoot for around the same year as yours tho... b/c '98 rear breaks were just wierd (not to be confused with in-effective). anything from 2000 on should be a bout the same tho.
my 2000 scrammy 400's rear brakes would always go bad.even after bleeding the brakes,,they would work for awhile but, not great and not long.I found that the rear brakes suck, no matter what you do/I did, they always went bad.The only way I could fix it was to dump the foot brake and in stall The brake split kit from hot seat.Now i have a hand brake just for the rear brakes and it locks up good. Also, braided brakes lines help too.the rubber ones expand under pressure.
He has already got braided brake lines, so does the Trailblazer. I think there is more to this rear brake problem than we know. Too many people, myself included have great rear brakes. Although split brakes might be a solution, it is not a solution for everyone.
Bryce
Bryce
The rear brake on a Polaris is not intended to be a main stopping brake but rather an auxilerie brake.
I have found that you can get the air out by bleeding them with the lid off of the resivoir but you have to keep an eye on it and not run it out.
my problemturned out to be my master cylinder I bleeded my brakes filled ther resovior up and secured the lid with new screws and yamaha bond. I havn't had a problem since. I think the seals just go bad real easy. maybe after the break has taken an impact( mine)
My sportsman 800 is on it's third new rear master cylinder. It only has 15 hours on it. I think I got a good one this time, so far anyway. Not sure if the scrambler uses the same master cylinder but if it does you can get one for $15 from these guys: Polaris parts
You can cross reference parts on the Polaris website.
