Trail Boss top speed
Old Dec 16, 2005 | 07:32 AM
zappa24's Avatar
Default Trail Boss top speed
I recently rebuilt a 1993 250 Trail Boss and it runs great.Not the engine just bearings,motor mounts, brakes and chain and sprokets. I am not happy with the top end speed I am getting from it. I'm sure the sprokets are stock sizes because I just replaced them and I am wondering if I can change them to get more top end. If so what size should I use and will I loose alot on the bottom end?
Old Dec 16, 2005 | 07:49 AM
ftwflh's Avatar
Before doing sprockets try putting in a Polaris white primary clutch spring.
Old Dec 16, 2005 | 10:45 AM
zappa24's Avatar
Thanks ftw, I have not had alot of experience with PVT chutches except to regrease the one on my Grizzly. I will try a white spring but what does it do to the gearing of the clutch? Maybe allow the primary chutch to open more to a larger diameter? Thanks for your help.
Old Dec 16, 2005 | 10:46 AM
zappa24's Avatar
Sorry, I should say close more
Old Dec 16, 2005 | 06:03 PM
ftwflh's Avatar
The white spring will give you a little more rpms on take off and more topend rpms. check your pms
mtdewmn
Jan 19, 2017 12:13 PM
Backwoods_badass
Aug 2, 2015 10:40 PM
Backwoods_badass
Aug 1, 2015 10:25 PM
black_thunder
Jul 28, 2015 11:05 PM
Gnuters
Jul 19, 2015 10:03 AM
