sportsman 50 smoking too much
I had that problem, my was a excessive amount of oil deposits in the exhaust. Low rpm riding will do that. Two things to fix it take it out and ripp around at high rpm for some time and or take a propane torch and heat the exhaust pipe cherry red. Have the machine running and start at the cylinder and work your way back.
Originally posted by: jayri
It's a 2-stroke, I'm pretty sure there's no oil filter.
Originally posted by: Bretman
well, its obviously burning to much oil. When you changed all the fluids, did you change the oil to, if you did, did you also remember to change the oil filter
