changes in 96-97 400 cylinder
Old Dec 22, 2005 | 07:21 PM
WIscrambler's Avatar
Default changes in 96-97 400 cylinder
hey guys-
Does the cylinder from a 96 Scrambler 400 fit a 97 Scrambler engine? I know the piston was changed mid year 1996, but did the cylinder change also? Thanks.
Old Dec 22, 2005 | 08:51 PM
16polaris's Avatar
I put a mild ported 96 jug on my 97 Sport. It worked just like the stock one.
Old Dec 22, 2005 | 09:57 PM
thanks 16polaris. However, you may have a late model 96 model jug that had received the updated piston. I want to know if the cylinder was updated with the piston or if it stayed the same.
Old Dec 23, 2005 | 12:49 PM
conig's Avatar
I think the updated piston goes with the cylinders that had boost ports added. 97-late 96.
Old Dec 26, 2005 | 12:05 PM
scramblered's Avatar
yes,only the '95 400 scrammy was with the jug as the 400 explorer
back then,'96 and newer 400 got the redesigned cylinder with a little
wider ports and such,a few more flow through the engine giving
a little more power,piston are all the same tough.
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
