Scrambler 500 bottom of steering stem loose..
It was a comon problem in the scramblers
when mine was new I knew about the problem so right away I took the riviits out and replaced them with small bolts and lock nuts a dollar or so fix and mine is still like new.
Hope this helps
Hope this helps
not to steel your thread but I think i have the same problem on my 2000 400 scrambler. It seems there is about a 1 inch play in the sterring column when you turn the bars back and forth. Do i just tighten the big nut on the bottom of the sterring column to fix this?
I don't think It's going to be that easy...Sounds to me like we might have to put in a new bottom steering stem bushing.{The stock setup sure is poor} I think I might call hpd or Rick"RCR" and find out how much they are..fun.....fun....[img]i/expressions/face-icon-small-frown.gif[/img]
Been there, done that. It's a very popular problem with 2000 Scramblers. I replaced both the upper and lower steering bushings. The steering is a bit tight for a while after they're installed, but they'll break in soon enough. You will think you have a new machine.
I had a local shop do my lower bushing, because I didn't have access to a 90 degree drill/dremel, and I didn't feel like disassembling the quad. With enough patience, it's something that can be done at home though...
badgerboy1
Sep 26, 2017 06:11 PM
Logan Collins
Sep 5, 2015 08:03 PM
