ATV Tire Chains
Old Dec 30, 2005 | 02:55 PM
OnWheels's Avatar
Default ATV Tire Chains
Anybody have an opinion on tire chains for ATV rear tires. I wondered if they tear up the pavement at all, or if that is a concern? Also, 2 or 4 link spacing - is one better than the other? What does 'V-Bar' refer to when it comes to chains? I would be primarily be using these for plowing traction on the rear tires, not for ice traction on lakes. Thanks
Old Dec 30, 2005 | 03:17 PM
floodrunner's Avatar
Tire chains are going to limit you to slow speeds. If you ever spin one loose you’re going to shred plastic (or even metal) in a heartbeat. If all you’re doing is slow snow pushing and you’re careful you’d probably be alright. ATVs are light enough that if you don’t spin your tires you shouldn’t damage “pavement.” Asphalt is softer than concrete so it depends on what pavement material you’re on. V-bar is an extra V shaped piece of metal that can be welded on the cross chains. It gives the traction chains a taller profile, longer life and better traction.
I had chains on all four rear wheels of a 2000 Sportsman 6x6 one winter. It had great traction in the deep snow but steering sucked.
Old Dec 30, 2005 | 03:26 PM
OnWheels's Avatar
Thanks for the insight Floodrunner. I don't necessarily need the chains, but I have had some intermittent issues with my 4WD quiting that I haven't been able to completely rectify. And as I am sure you know, if the front wheels aren't there, it's hard to move much snow. So I thought some chains on the rear wheels would be a nice backup if the 4wd does quit.
Old Dec 30, 2005 | 07:23 PM
2manytoys's Avatar
I use tire chains on my 2wd 330 and they work great in the snow. I can go just about anywhere and push alot of snow. My driveway is blacktop and it does not affect it at all.
STLyamwar
Jul 25, 2020 04:44 AM
Hondapolaris8596
Jul 28, 2016 03:17 PM
frostphase
Aug 23, 2015 07:36 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
95wolv
Jul 17, 2015 08:13 PM
