just got new rear master cylinder and dead again!!!wtf
I would complain to these guy's. Polaris don't care. I've tried before. It's a waste of time.
http://www.cpsc.gov/
It will still happen no matter how you bleed it. The master cyl. is a bad design. It leaks air into the seals. Take it from me, I use to be a old wrench from way back. Now I'm a mechanical engineer. Your going to have to deal with it or go with Fixitmatt solution. Or you can bitch about it and make Polaris recall it. It is a safety problem. Somebodys life can depend on it.
Just go to: http: www.cpsc.gov
And click on to: Report an Unsafe Product
#15
Hello garrett5462. I would suggest you look at this thread.
Brake It is clear that no one seems to know what the problem is in all cases. Many quads rear brakes work just fine and others seem to have problems. I would not go out and buy a new master cylinder without checking the points listed on the above thread.
Bryce
Bryce
Stirling
08-09-2015 01:49 PM
SixSpeed5
8
08-02-2015 05:38 PM
willday08111217@gmail.com
Technical and How-To Articles
08-01-2015 04:05 AM
