650 Kawa update
Old Nov 5, 2000 | 07:31 PM
Snowride's Avatar
Sorry the correct terminology is an imperial gallon. The reason that the spec sheet is in liters and imperial gallons is that I am from canada. I saw the quad at a canadian show.The canadian division of kawasaki called Kawasaki Canada was showing the bike.Let me through another one in here for you. The 400 prarie in Canada is called a KVF 400 and the new 650 is a KVF650.
Old Nov 5, 2000 | 07:48 PM
ledebuhr1's Avatar
thanks for your help, next time i go to walmart i might pick up a set of driving lights. being that the sportsman has a 250w alternator(i think) would it be safe to put the light switch in between and run all three lights at the same time? boy if u could it would really put out some light
later
jon
Old Nov 5, 2000 | 07:51 PM
ledebuhr1's Avatar
thanks for clearing that up. i have never heard of a imperial gallon.
later
jon
Old Nov 5, 2000 | 08:47 PM
Snowride's Avatar
You can say that again, On my xplorer or on any polaris with the same type of light switch you can position the switch between the high and low beam position and both sets of lights will come on. If I leave the switch like this for more than a few minutes the lights will start to dim slowly because the charging system can't keep up. I use it once in a while when extra lighting is needed. It looks like someone turned on the lights in the ball park. 2x55watt,1x100watt = 210watt through 3 lenses.
Old Nov 6, 2000 | 06:18 PM
  #15
Thor's Avatar
Don't you live right across the river from Sarnia, Ontario? Hmmmmm?
Old Nov 6, 2000 | 06:50 PM
  #16
ledebuhr1's Avatar
yep i sure do, i am a little over a mile from the river and just across the river is CANADA.
later
jon
Axl_Z
Mar 9, 2025 11:14 PM
chewy78
Sep 8, 2015 10:37 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
ModdedX
Jan 23, 2001 09:56 PM
uh008
Dec 30, 2000 04:26 AM
