Cutting the plastic on my trailblazer.
I used a jig saw with a fine tooth blade, I just used masking tape to draw out the lines and then just followed the tape lines. Then like stated above just sand the rough edges off and it'll be in good shape!
i taped thick plastic to mine and drew an out line of the fender and what i was going to shave off then i cut my templet out and was able to use it on both fenders to make sure it was even.
i cut the plastic with a dremmal and i could not belive how easy it cut like a hot knife through butter....
Talonhawk and Jayblazer both of you did a real nice job on cutting your fenders and fixing up your atv's. I have two trailblazers I'm trying to convert. Where did you two find your front bumpers w/ skid plates. Did ya remove the stock front ends.
the front end comes off with 4 bolts and i got that bumper from a guy who use to be on here all the time named MODQUAD. but you can get them on ebay for cheap...
My bumper is from DG and I had it powder coated black to match the frame. Like jayblazer said,
the frames for the trailblazers and scramblers are the same but the DG bumper for a TB won't
fit a scrambler because of the radiator the scramblers have.
