engine died
Old Jan 8, 2006 | 09:58 PM
700r's Avatar
Default engine died
hi i have a question for you guys. today i was riding my scrambler400 in the snow and it just shut off, just like i hit the kill switch, but i didn't. when i hit the starter the motor turned over very fast with no resistance at all, thought the starter gear broke so i pulled the pull starter and it was like it wasn't hoohed to anything but the engine turned over, then i realizede that there was no compression. i hit the starter again and i could barly feal any air come out of the exhaust. this engine just had a new topend 10 hours ago so it isn't worn out. what do you thing the problem is, any advice will help , thanks
Old Jan 8, 2006 | 11:09 PM
SPORTSMAN70003's Avatar
Default engine died
Sounds like it was run lean and melted a hole in the piston.
Old Jan 9, 2006 | 09:02 AM
JjEjFjf's Avatar
Default engine died
This may sound stupid but: the sparkplug didnt come out did it?
Old Jan 9, 2006 | 02:18 PM
700r's Avatar
Default engine died
no the plug isn't out. but earlier that day it would bogg down like it was lean, but not too bad thanks
Old Jan 9, 2006 | 10:02 PM
700r's Avatar
Default engine died
SPORTSMAN70003 you were exactly right i took it apart and there was a hole the size of a pencil on the edge. then while i was taking it apart i found that the temp light wasn't hooked up at all and the top piston ring was melted to the piston. i wasn't riding it while it died my 11 year old cousin was riding it. i wish that i was on it so i could have shut it off earlier when it was bogging down. the cylinder is scraped up prety good. will bore it out evean more. when i fix it do you think that i should sell it right away or will it last a while. are these motors any good with a wiesco piston
Old Jan 9, 2006 | 10:11 PM
Default engine died
I just rebuilt a friends 400 Sport not to long ago it had a small hole melted in the piston. I would put a Wisco piston in it if I were you. Also you need to go bigger on your main jet. It dosen't take long to burn a hole in the piston if you run it lean.
Old Jan 9, 2006 | 10:14 PM
700r's Avatar
Default engine died
ya it took about 7 hours to burn a hole. is it hard to change the jet
Old Jan 9, 2006 | 10:40 PM
Default engine died
Its not bad just take off the bowl on the carb and you can get to it from there.
txpedsrt1
Feb 3, 2017 08:07 PM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
