Voltage regulator
Old Jan 11, 2006 | 09:29 AM
coachp84's Avatar
Default Voltage regulator
Is there a way to test a voltage regulator to see if it is working properly?
Old Jan 11, 2006 | 09:18 PM
SportsmanEE's Avatar
On what kind of bike?
In general: measure AC voltage btw each leg of the stator. The voltage varies depending on which stator you have, but should be the same btw each of the legs and should increase as rpm increases. You can also check DC voltage at the battery. It should be ~12.7ish with the engine off, 13.5ish at idle and 14.4ish at high rpm.
Joe454
Nov 20, 2020 01:19 PM
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
