Secondary clutch settings?
Old Jan 16, 2006 | 07:35 PM
2manytoys's Avatar
Default Secondary clutch settings?
Rick, bubba, anyone? Can anyone tell me what all the secondary clutch spring settings are and what they do for performance positive or negative?
Old Jan 16, 2006 | 07:42 PM
ncriderforks's Avatar
spring ends factory should be on 2 and 2. 1+3 would tighten the spring alittle and make the clutch advance take alittle longer. Not really a + or -. Just depends on your riding style and how you want the response to be.
Old Jan 16, 2006 | 08:03 PM
2manytoys's Avatar
I know the factory settings and how to set them up but I just want to know how all the settings will affect the performance. I want to have all my power down low and not let it shift out as quick. I know the tighter the spring the slower it will up shift , the looser the spring the quicker the upshift but what will happen if it is too tight or too loose. I was climbing a hill about 100yards long but lost all my power about 3/4 of the way up. Would changing the spring position put more power down low to e it climb easier.
Old Jan 16, 2006 | 08:49 PM
ftwflh's Avatar
Is this on your 330? If so I ended up going with my Aaen blue set at 2-2 and it was much better than the stock spring.
Old Jan 16, 2006 | 09:00 PM
2manytoys's Avatar
Yes it is for my 330. Like I have been saying I think the pink is the best spring for the primary but I need to tune the secondary better. Does the blue pull harder up hills?
Old Jan 17, 2006 | 12:10 AM
ftwflh's Avatar
I havent tried it on any steep hills but in various conditions it does real good.Backshifts better and holds the rpms down some too.If the weather ever gets nice enough around here I will give it a good test and let you know.Getting older and I dont like the cold weather like I used to[img]i/expressions/face-icon-small-frown.gif[/img]
Old Jan 17, 2006 | 08:24 PM
2manytoys's Avatar
ghost civic
Jan 15, 2020 07:43 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
