questions for sportsman 70003
I see you have the 800 pipe and white brothers muffler, I'm thinking of buying them. how much louder is it than stock? Did it help quite a bit with power? And have you done any playing with the number of disks in the muffler, what seems to work the best?
Thanks ,Russ
Thanks ,Russ
I have a video clip here that might help you see how it sounds. So far I have 6 disks in with a quiet core. I have played with the disks and like the 6 disks the best not to loud and plenty of power down low. The more disc you add the more it helps top end end the more you take off the better bottom end will be. I fill with the 800 header and White bros. I gained very good results.
