first ride on my predator... :-D
Old Jan 31, 2006 | 05:55 PM
  #21
spyder6's Avatar
Default first ride on my predator... :-D
that dosent sound correct at all. and please, stop typeing in all caps
Old Jan 31, 2006 | 06:33 PM
  #22
fattychris's Avatar
THAT'S WHAT THE SPEEDO SAID CALL TRAIL TECH AND TELL THEM THAT THEIR WRONG IF YOU WANT TO. AND I LIKE TO TYPE IN CAPS!
Old Jan 31, 2006 | 09:59 PM
  #23
Webopper's Avatar
Oh, I believe it...them custom ground effect lights are good for at least 10MPH...LMAO.
Old Jan 31, 2006 | 10:16 PM
  #24
fattychris's Avatar
IT'S A DUNE THING. IT HELPS MY STUPID FREINDS FROM GETTING LOST ON NITE RIDES AT THE DUNES. IT HELPS IF THEY CAN RECOGNIZE YOU OTHERWISE THEY MIGHT START FOLLOWING SOMEONE ELSE THEY DON'T KNOW, AND I THINK THEY HELP THE AERODYNAMICS OF THE QUAD!![img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 31, 2006 | 11:49 PM
  #25
spyder6's Avatar
well even if you like to type in all caps, its against the forum rules to do so. i still cant see 87 mph out of a nearly stock quad. i can understand were your plus 4 swing arm would help killing 700r's but 87 dosnt sound right unless your going downhill or your speedo's off
Old Feb 1, 2006 | 12:23 AM
  #26
fattychris's Avatar
i also run 22 inch taller haulers. they might help the top end? the speedo may be off but acording to the trail tech instructions on how to measure tire roll out and set the speedo calibration it should be close? sorry about the caps, i did not know about the rule. i just thought you were getting jerky with me for nothing.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 1, 2006 | 08:12 AM
  #27
spyder6's Avatar
your taller tires have something to do with it. im not sure how the trail tech computer gets its speed data, but if its hooked up to your chain and you installed it before you put your longer swing arm on, the distance between your sprocket and your axle might have changed enough to screw up your computer
Old Feb 1, 2006 | 11:47 AM
  #28
fattychris's Avatar
it has a speed sensor on the front wheel.
Old Feb 1, 2006 | 01:46 PM
  #29
Webopper's Avatar
yea chris, not trying to burst your bubble or anything, but you probably want to recalibrate it.
Old Feb 1, 2006 | 02:37 PM
  #30
fattychris's Avatar
that's what it sounds like.
Nondem
Feb 22, 2020 12:20 PM
HondaR24
Jul 16, 2015 10:45 AM
honda71
Jul 12, 2015 05:56 AM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
honda71
Jul 8, 2015 02:13 AM
