rcr porting questions
Old Jan 26, 2006 | 10:09 PM
700r's Avatar
Default rcr porting questions
hi i have a scrambler 400 and it just blew a piston. my dad says to get new berrings and wiesco piston and put it back together, to be stock, i think that it is a waist to rebuild it back to stock when RCR can port the cylinder. and shave the head also. and put a stage 1kit pipe on it. what kind of performance can his porting do to the motor. i ride fast on trails and wan't more power will this do the trick. how reliable will it be after porting, will a griddle be nesisary. i am only 16 and can't be spending too much on it, scence i have to do the botom end.
If rick reads this can you please wight back. it would be very helpfull and if i like what you say about the motor maby i will give you a call ship out the cylinder. i will need the cylinder boored, ported, head ported, piston, stage 1 kit, and maby a tach to toon in the clutch.
Thanks
Old Jan 26, 2006 | 10:17 PM
16polaris's Avatar
YES! If you can afford it I think you should have Rick to trail port it and shave the head for pump gas, This will bring to 400 to life, Give Rick a call, he's a GREAT guy and will give you an HONEST answer. And his prices are GREAT also. Just my $.02
Old Jan 26, 2006 | 10:47 PM
2manytoys's Avatar
You can port the jug but to get the full effect of the port job you need the pipe. Porting and adding a pipe will give you about a 10-15hp gain and the 400 will scream. You dont port the head you port the cylinder. The head does not have ports. You can get a cool head for it. It is great what a good port job, pipe and proper clutching can do to the 400's. I would get the girdle kit to be safe but your not raising the compression that much for pump gas. At a minimum go with the wiesco piston, pipe, slight bore and head milled. If you can swing it do the port job.
Old Jan 28, 2006 | 12:40 PM
700r's Avatar
thanks for the information, i was wondering how long the engine will last with the port job, what about how reliable it will be. hard to keep running, hot weather, cold weather?
QuadRiders
Oct 22, 2015 04:13 PM
Brandon400
Sep 5, 2015 08:44 PM
toonces
Sep 5, 2015 01:14 PM
