v force reeds & carb ?
Old Feb 5, 2006 | 10:34 AM
scramblerxrider's Avatar
Default v force reeds & carb ?
i have heard that v force reeds are the best
will they make a noticeable differance
how will they affect jetting
i have been told they flow more gas
also i have heard the 38mm mtx carb works better than stock
will this carb be better and is it to much for a mild woods rider
does anyone use this combo with a pipe
thanks for any input.
Old Feb 5, 2006 | 10:51 AM
16polaris's Avatar
I personally like the V Force reeds, I think as far as the carb goes I would go with a 39 PWK, and when you get the carb you can jet it properly. just my $.02
Old Feb 5, 2006 | 11:36 AM
handycap's Avatar
One of my 400 Polaris's is stock with all the add on's below.
No port work, stock piston for 2 years of hard running, just the pipe and stock silencer now, V-Force 2 peddle reeds, 44mm carb, K&N air filter and HPD clutching. I have the jetting at 300 main and its a little fat.
I was told by a few that this wouldn't run well at all, but it does, it flat fly's, it wheelies like nothing even at 15-20 mph and it still pulls up. I pull a 5' Trailmower with it also to mow my property.
Go with a larger carb for mods later, it is still easy to woods ride. I think I am going back to stock front spring. The high engagement is a little much with the HPD Red/silver strip.
Old Feb 5, 2006 | 11:51 AM
Fastestdad's Avatar
I would het a 39mm pwk way before the 38mm. I'm also having real good power with a ported stock reedcage and a $40 set of boyesen reeds. I have both a Vforce and stock ported. I think I'm gonna use stock ported from now on.
Old Feb 5, 2006 | 02:46 PM
Whitedog's Avatar
I agree with the rest of the guys on the carb. The 39 is supposed to be better than the 38.
The boysen rad valve was the first mod I did to my 4x4, back in 99. I think I gained approx one bike length. over my buddy on his stock 400 4x4.
Also, Dennis Packard told me that the boysen was a better valve than the v-force. Although i have always read just the opposite. So.... I had to compare the two. (Ive got the v-force on my racer) heres what I found - The boysen is completely made of aluminum, has a larger opening than the v-force, plus the boysen has a dual stage reed setup. Which is supposed to help out on the bottom end. The v-force is made of plastic and has single reeds.
My vote goes for the boysen.
My 2cents
Old Feb 5, 2006 | 11:04 PM
hey thanks for the reply's
seems like the 38 mm tmx is not the best choice
i'll look into the other carbs
Old Feb 6, 2006 | 09:35 AM
scramblered's Avatar
go for the rad valve or the v-force 2 with reed spacer,you didn't
need extra spacer on the rad valve tough,similar performance gains
and response ,ost too especially on a ported cylinder.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
