Anyone run high octane??
Old Feb 11, 2006 | 01:47 PM
SCRAMIN's Avatar
Default Anyone run high octane??
that what i was trying to say is cooler is better once engine heats up
Old Feb 11, 2006 | 01:48 PM
YFZracer12's Avatar
I run 110 race fuel in my YFZ and alcohol in my DS 730
Old Feb 11, 2006 | 02:26 PM
gunman457's Avatar
Originally posted by: drlang
I have .020 off the head on a 250. I found I need to use 93 octane or it pings.
You need more octane as you raise your compression. Other then that, higher octane is a waste of money. It don't make you go any faster unless you raise your compression.
Old Feb 11, 2006 | 05:16 PM
Zbart1's Avatar
Well I will try to give you a short version of this :
premium gas was and is designed to protect your engine against detonation. and it does this because of the chemical makeup of long branch tightly bonded molecules. Where regular gas has a molecular structure that has less of a bond.
The chemical composition of the fuel determines how fast the fuel will burn and if it will work well with high compression or temperatures.
fuels with weak molecular structures [regular] will break down more quickly or burn spontaneously [detonation] at lower temperatures.
Fuels with tight molecular structures [ premium] burn more slowly and take more pressure and heat to fully break down and burn.
therefore putting premium fuel in a engine not designed for high octane fuel [I e not having high compression or spark advance ] will not be able to break down the chemical bonds. And will not completely burn the fuel charge therefore produce less power.
So you see next time your at the pump buying that 115 octane racing fuel for your sled that costs five dollars a gallon. you may want to reconsider.
Run the type of fuel your manufacturer recommends !!!!!
Old Feb 11, 2006 | 06:19 PM
  #15
zerowick's Avatar
thanks Zbart1!
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
