Help - Gear selector fluid
Old Feb 14, 2006 | 09:16 PM
alwazmt's Avatar
Default Help - Gear selector fluid
I am in the middle of replacing my '95 Xplorer gear selector with a gear selector off of a 96 Xplorer because of a broken electrical switch. I thought I could just replace the switch, but it seems that the 95 and 96 switches are way different. The '95 switch is a plastic piece of #$%#$. Anyways, the gear selector form the '96 has no fluid in it since I opened it. I am going to go ahead and replace the whole selector. What is the fluid in the gear selector?
Thanks,
Jim
Old Feb 14, 2006 | 09:37 PM
highwayman's Avatar
alwazmt I think it may be 10w30 but try a search, thats where I think I read it.
Old Feb 15, 2006 | 07:48 AM
ftwflh's Avatar
10w30 or 10w40 motor oil is ok.
Old Feb 15, 2006 | 10:40 AM
alwazmt's Avatar
Thanks for the info, guys. Hopefully we'll get'er back in tonight........
Old Feb 17, 2006 | 01:58 AM
HuntinAddict's Avatar
Do all Polaris have this Gear selector fluid that must be checked? If so How do you do that? Thanks
Old Feb 17, 2006 | 06:56 AM
highwayman's Avatar
Just take the plastic panel where the gear shifter is and remove 4 screws on top of the shifter box. Be careful a couple of years ago I checked mine and when I put it back together I didn't have to use the reverse override button. I also lost the nuetral and reverse lights on the dash.
cornermike
Aug 10, 2016 06:47 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
MATT BOOTH
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
