What will 45/40 helix do for performance?
Old Feb 18, 2006 | 11:59 AM
WIscrambler's Avatar
Default What will 45/40 helix do for performance?
exactly what the topic says...what will a 45/40 helix do for the performance on my modded Scrambler?
Old Feb 18, 2006 | 12:45 PM
POLARISFREAK's Avatar
It will more than likely bog the motor due to upshifting to fast. You need a race mod setup to try and run it. It's pretty much an all out drag race helix. Backshifting will not be good.
Old Feb 18, 2006 | 03:22 PM
scramblered's Avatar
WI,i'm running a 44-40 HPD helix in mine,engage at 4350 then shift
straight away to across 7600 rpm,race mods engine,only hot seat offer a 45-40 and looking to try one this summer as i can load it even more
and still belt doesn't climb to the very top be pretty close (1/8).
as you motor is stronger it will pull the stiffer angle through the range no problem,clutch weight is a must fine tune thing in this case to still
properly pull hard and determining the proper secondary shim behind the snap ring is very importing also,allowing you to decrease or increase
helix starting angle.
Old Feb 18, 2006 | 04:36 PM
duneaholic's Avatar
I ran a 44-40 helix and man I hated that thing. Just like Polarisfreak said. It was frickin horrible. I like the stock helix myself.
Old Feb 18, 2006 | 04:51 PM
OK, 45/40 helix is out of the question. I need something else because my helix is getting grooved pretty bad and I need new buttons also. I'd hate to put new buttons in just to have the grooved helix ruin them right away. Can I grind down my stock helix to remove the grooves?
Old Feb 18, 2006 | 05:23 PM
duneaholic's Avatar
I've done mine that way and it still runs good.
Valder
Nov 28, 2020 07:38 AM
Customer Service #1
May 15, 2020 08:46 AM
Sep 30, 2015 01:37 AM
jankerstien
Sep 21, 2015 03:09 AM
