1998 Sportsman 500 Not Starting Help
Old Feb 20, 2006 | 12:57 AM
RockDog's Avatar
Default 1998 Sportsman 500 Not Starting Help
I have nver had problem wiyh it, I drove into my trailer after riding, took it home went to start it it would not start. Changed plug cleaned carb and still nothing. Have fuel and spark but won't fire. Please help if you know anything.
Old Feb 20, 2006 | 01:08 AM
Polaris500HO4x4's Avatar
Check you ETC for correct adjustment
Old Feb 20, 2006 | 01:10 AM
RockDog's Avatar
What's the ETC
Old Feb 20, 2006 | 07:55 AM
ftwflh's Avatar
TRy adjusting the valves.And checking compression.
Old Feb 20, 2006 | 07:22 PM
very true you may have lost just enough compression so that the engine still runs but does not start.. remember you engine does need more compression to start then run
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
gfl0224
Jun 27, 2015 06:52 PM
clsharky
Jun 8, 2015 11:38 AM
1000gade
May 27, 2015 12:37 PM
