AWD shuts off after half throttle
Old Feb 22, 2006 | 09:40 AM
Krafka's Avatar
Default AWD shuts off after half throttle
We were driving on our frozen lake last weekend when all of a sudden I felt my front tires disengage and started spinning out of control. So I did a test and watched the AWD light after i passed half throttle and sure enough it turned off and I felt it disengage I continued my test for about 45 minutes and everytime I got over half throttle my AWD turned off and everytime I left off the throttle the light turned back on and I could feel the AWD re-engage
Old Feb 22, 2006 | 01:01 PM
dontgetbehindme's Avatar
The spinning thing sounded like fun.[img]i/expressions/face-icon-small-smile.gif[/img] Do you think that the ice had something to do with it? I know that the awd kicks in and out if it sees slipage, and if the wheels wasn't slipping at that point it may have kicked out, but when you started losing control did it try to kick back in, or could you tell with all the excitment? It may be a sensor going bad. Maybe someone can help better.
Old Feb 22, 2006 | 01:21 PM
Krafka's Avatar
it did it everytime at a certain speed i know what you are saying but ive never had the light go off and if i let go of the throttle it light back up without loosing much speed
Old Feb 22, 2006 | 04:32 PM
I was checking a repair manual and take the throttle and AWD switch housing apart and see if the throttle cable is ok and the wire in the switch is not contacting anything, check and make sure the wire is connected good at the switch, may be as you put psi on the throttle it is pulling the wire out. Just some things to check. May be a loose wire.
Old Feb 22, 2006 | 04:34 PM
What kind of quad is it? Do you have a speedometer on it, if it certain speed it may be a speed sensor.
Old Feb 22, 2006 | 04:42 PM
Krafka's Avatar
2003 scrambler 500 H.O. 4x4
scram5050
Aug 30, 2024 01:39 PM
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Polarisman1123
Sep 13, 2015 10:06 AM
