To lift or not
Old Feb 23, 2006 | 01:36 AM
4x4marvo's Avatar
Default To lift or not
Ok 2002 700 sportsman i wanna put a highlifter 2 inch lift. I have heard both good and bad, what is the bad? What is the good. Please help!
Old Feb 23, 2006 | 02:26 PM
Silversteinfan's Avatar
What do you do on your quad?
Old Feb 23, 2006 | 05:20 PM
Polaris500HO4x4's Avatar
Bad= CV joint repair $$$$$$$$ and premature wear on brakes and drivetrain, more tippy
Good more ground clearance= biggertires and that goes back to ^^^ and thats about it
remember the polaris already has 11.25"
Old Feb 24, 2006 | 05:07 PM
4x4marvo's Avatar
i trail ride and mud alot, just wanna have a big bad atv...lol
Old Feb 24, 2006 | 11:57 PM
Andre's Avatar
Well, I went for it. I just finished installing the Xtreme Products 2" lift front and back, EPI HD springs and Gorilla axles. I'm going for a trial run in the morning, we're supposed to get 3-5 inches of snow.
I needed to get a couple more inches of GC to stay above the rocks on the trail, kinda like "tip of the iceburg" rocks, 12" of rock sticking up on the trail and 4 ton boulder beneath it. With the 03 model I could'nt go much taller than 26" tire without serious tire rub, so I went with the lift.
The hardest parts of the install is getting the stock axles out and removing enough of the strut housing material to clear the bigger Gorilla boot combined with the steeper axle angle. The machine does look lifted and with the rear shocks cranked up 3 notches the rear end sticks up there, I may crank it back down. Anyway I spent the big bucks up front to avoid problems on the trail, we'll see. Those Gorilla super duty axles are plenty beefy.
QuadRiders
Oct 22, 2015 04:13 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
