Moose plow, Clevis pins?
Old Feb 23, 2006 | 05:31 PM
2brokenlegs's Avatar
Default Moose plow, Clevis pins?
I have a 60' moose on my 335, What I am woundering is this. The plow is mounted with
two clevis pins under the bike. I replaced them a bunch of times, then found stainlesssteel pins.
This worked for a little but they still bend or dissappear. I like how easy it is to remove
and install, but I dont want to keep replacing thesse silly little pins. Any ideas? Thanks Nate
Old Feb 23, 2006 | 06:25 PM
Fireslayer's Avatar
You could use something like grade 8 bolts thru them with locknuts or jam two nuts together to prevent them from coming off. This won't be near as quick to remove/install as the pins are but if you don't take the plow off and on much it won't cost you much extra time.
Old Feb 23, 2006 | 06:58 PM
Thanks, thats kinda what I figured. Didnt want but I will probably have to.
shimanok2
Jan 29, 2016 07:37 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
tysonbully
Sep 28, 2015 02:30 AM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
