05 sp 700 efi check engine reset?
My check engine came on on this -20c day,got codes 46 and 41,barometric pressure sensor high input,intake air temp sensor open or short.
Would like to reset to see if they come up again.disconnected the battery and it did not reset,any ideas before taking it for service?
The T-Bap sensor connector / patch kit is now available from Polaris. Don’t know the part number or price but your dealer should have the info, mine does. Or you can use the repair method I posted about two weeks ago, just search for T-Bap.
I fixed Mine last spring also... the T-Bap sensor harness had rubbed through against the Crankcase Breather hose... I posted the findings and results then, and it has been fine ever since. Does the new harness repair kit come with an extra shielding around it to prevent this again??? I just wrapped mine with automotive electrical conduit and zip tied it sucurely away from everything. Dan.
SOLOLUCKY
Oct 4, 2024 09:09 PM
in2atvn
Sep 20, 2000 04:58 AM
