Looking for help! 500 scrambler, clutching, exhaust.
i have a 2004 scrambler 500 and i have a few questions: i got some clutch springs (primary/secondary) from rick ritter, i don't remember exactly what they are, but the primary has pretty high engagement. that is why i took it out. i didn't like it at all. it felt very jerky, made it hard to climb/crawl, and seemed to smoke the belt. hated it. didn't really notice what the secondary did.
so, i have heard that the 500's are very underclutched from the factory, so i still want to put a kit in it. i want a primary that is at or close to factory engagement, a good secondary, weights, helix, whatever i need. team roller if i can still get one. i will prob do the airbox mod. what do i need?
i also want a good pipe. i was thinking white bros e-series slip-on? will that dictate my clutching, or vice versa, or what?
my goal here is to get as much power as i can get, torque mainly, as torquey as it can get (A TORQUE MONSTER!!!!), with good top end of course.
that said, i ride slow as much as i do fast, lots of crawling, etc, so i don't to lose that capibility at all.
help is greatly appreciated.
EDIT: i am also contemplating an explorer trans for the 4x4 low. would that affect this stuff at all?
EDIT 2: i can't find a white bros e-series slip-on for the 04?
If you cant find a WB pipe the FMF is ok and Aaens slipon with spark arrestor is good too.
On your clutching I would call Rick and tell him that the spring you got from him didnt suit your needs and I bet he will swap with you for one that will work for you.Most likely a Dalton blk/white.
Hotseat did have the TEAM secondary and HPD can set one up for you too.
And yes it is worth every penny.
http://www.hotseatperformance.com/ps...2901&CATID=248
do i need this?
http://www.hotseatperformance.com/ps...2903&CATID=248
You need the TAS98 but the 99 can be modded to work on non ebs
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
cdstang
Aug 31, 2015 07:52 AM
