Advice
Old Feb 26, 2006 | 11:29 PM
bowlingman1017's Avatar
Default Advice
Hey everybody. i recently purchased an 02 trailblazer 250. its in total disarray. it needs front fenders a muffler and an ignition switch. I need some advice. What would be the best exhaust to put on this bike? stock or pay the extra 100-200 dollars more and buy a performance exhaust. if so, which kind and what should i look for? what about a clutch kit? what should i do about it? should i get a performance kit too if i get a better exhaust or leave it stock? from what i've heard the bike cant keep up with some of the other 250 quads, im wanting to add some HP so i can and out run the 250ex and the 250 quadsport. and to destroy a blaster [img]i/expressions/face-icon-small-smile.gif[/img]. any ideas?
-thanks
Old Feb 27, 2006 | 08:00 AM
ftwflh's Avatar
Default Advice
Call Rick Ritter and get his stage1 kit.
Old Feb 27, 2006 | 08:15 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default Advice
ditto
Old Feb 28, 2006 | 12:01 AM
Default Advice
thanks. i checked it out and might buy it. one more question, how do i tune the clutch? i would like to know how to do one before i bought the kit. hoping that maybe i can do something b/4 spending that kind of money. also, how much weight can you safely take off the flywheel? i've heard up to 13 ounces, but i've done all of mine on vws and figured i can do the same on my polaris...ne suggestions?
Old Feb 28, 2006 | 08:03 AM
ftwflh's Avatar
Default Advice
Tuning a clutch is an indepth process.But for cheap mod a spring change is what most do.Get either a Polaris white or green primary spring.
Old Feb 28, 2006 | 10:07 AM
2000scrammy's Avatar
Default Advice
I would definitely go with a RCR stage 1 kit, I'm gonna get one whenever I get my tax return back. Rick will hook you up with the correct spring for the pipe that you get from him. While your getting that kit just ask him about the flywheel, he knows a lot better than I do.
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
